If your tire size is correct and you've got all the normal parts for an 88 non-turbo, that should be spot on. Gears are gears, they don't change
Tire size will make a bit of a difference though if you're bigger/smaller.
[That chart I made is figuring a W58 5-speed, a 4.30:1 Rear Diff (Final Drive), and 225/50/16 tires which should be stock on an '88 N/A.)
