first thing to do is check the oil level.
some people can hear the injectors and think they make a lot of noise.
the lifters could be getting older and noisier.
pictons, rings, bearings all can make bad noises.
loose crankshaft pulley can make a banging noise.
also a loose timing belt tensioner.
try using a piece of hose stuck your ear while moving around the engine bay to locate the noise. you'll be amazed at how well it works.
if your engine sounds like a blue man group concert, then im afriad it may already be too late.
