Transmission Drain plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2008, 04:05 PM   #1 (permalink)
View suprabran's Photo Gallery
What size socket is the right size for a transmission drain plug, and the differential drain plug? And are the filler plugs the same size? I have to head up to autozone or NAPA for some bigger sockets I want to make sure I get the right sizes for both.
suprabran is offline   Reply With Quote
Old 07-09-2008, 04:50 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
You fill the transmission through the hole the shifter goes into.
I can't recall the drain plug sizes.
Old 07-10-2008, 01:52 PM   #3 (permalink)
Okay thats cool, so do you have to pull the shifter out with the boot and part console? Also if you do get the plug size is it the same as the differential drain and fill plug?
Old 07-10-2008, 04:17 PM   #4 (permalink)
View SupraTuned's Photo Gallery
Transemission
Your transmission drain plug is a 17-18 mm if I remember right. While your at the auto store, buy your tranny fluid in a 1 gallon jug.... its the perfect amount to fill your tranny. You can also buy a small universal jug pump for about 4.00 that will allow you to screw it onto the jug and pump it into the tranny from below. Good for rearends as well.
SupraTuned is offline   Reply With Quote
Old 07-17-2008, 04:57 PM   #5 (permalink)
Is the differential different? Because I have a 23mm that don't fit it it is still too small.
Old 07-20-2008, 01:49 AM   #6 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
Well they got the tranny covered, as far as the rear end goes i've seen that almost all Toyotas have the same size rear diff check plug socket. I cant recall what size though. I think 26mm...? I can find out in the morning.
If you're gonna re-fill the rear diff, and its LSD, make sure to add the LSD additive
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 07-21-2008, 03:26 PM   #7 (permalink)
I Bleed TRD
Hey I dont know if you found out or not but its a 24mm for the rear diff. 15/16 works too
Old 07-24-2008, 02:45 PM   #8 (permalink)
cool thanks so much! I was thinking 24mm the 23mm almost fit.
Old 07-25-2008, 12:10 AM   #9 (permalink)
I Bleed TRD
hey no problem. I used to work at a Jiffy Lube but I forgot what it was. Just had to call my friend and ask lol.
Old 07-25-2008, 10:47 AM   #10 (permalink)
I just changed the differential today, it makes so much of a difference the oil was black, it was really nasty. I think I over filled it a little is this okay? It was on a slight hill though so I put some in until it ran out and stopped that about right isn't it? at the very top of the fill plug or does your finger have to get in there with a little space? Well I am going to do the transmission hopefully in 3 days it started raining on me. But thanks everyone for the information!
