Knock sensor can be a serious issue, it will cause VERY pathetic performance. I don't know if you can just replace those clips, but toyota doesn't sell them on their own either. I know driftmotion makes a repair kit.
The speed sensor isn't a limiter. It's an actual malfunction.
Diagnosis : No "SPD" signal to ECU for 8 seconds when engine speed is between 2,500RPM and 4,500RPM (7M-GE) or 4,000RPM (7M-GTE) and coolant temp is below 80°C(176°F) and neutral start switch is off.
This is not the ABS Wheel speed sensor.
