Thanks for the reply Bob,
Well i havnt really posted enough info to support my drama. The car has been on three seperate Dyno's for a total of 2 dozen or so runs. Boost level is set to 20 psi. Turbo is capable of around 550 hp i am told and i have just had it serviced - bearing redone but no dramas with comp wheel etc. Cam timings have been checked but no problems there.Fuel pump flow tested, injectors tested, K&n 12 inch filter pod replaced,exhaust checked - catalyctic converter was partly colapsed but now has been removed. New high flow fmic installed.
Several car tuners have gone over the car and all have come back to me with the same question - The motor is underperforming and the compression is too high for a 1jz-gte, is the motor a 1jz-ge?
I honestly think that the company that replaced my motor have pulled a shiftie on me and probably thought that i wouldn't find out. I know that they could have saved alot of money by only supplying a 1jz-ge and i had allready supplied them with the garrett turbo, exhaust manifold etc to put on it. I will not, however, accuse them or take it further if i can not get difiniative proof that they have supplied me with the wrong motor, hence my question - can i tell from looking externally weather the motor is a 1jz-gte or a 1jz-ge?
Supramansolo
Reason: spelling mistake (1)
