1JZGTE Fresh build- how do I scan codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2008, 05:25 PM   #1 (permalink)
View agrabau's Photo Gallery
http://www.youtube.com/watch?v=B6Gq2_OqgLI
I just finished a strange build using a 1jzgte. She's running and idling fine but running visibly rich (smoke that smells like fuel) and also engine speed won't exceed approximately 4000 before hitting a wall of misfires.
I guess I should be asking how to read codes on this engine package, then asking for possibilities on why it's not building boost or reving over about 4k. I say about because I haven't hooked the tachometer up yet.
Here's a picture of the project.
agrabau is offline   Reply With Quote
Old 07-23-2008, 08:11 PM   #2 (permalink)
To add some information- there is a leaking capacitor on the ECU board. I'm going to replace it tomorrow and see if that helps. I think that all of the wiring is right.
Here is a cat drinking some milk. My is he thirsty.
Old 07-23-2008, 09:19 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
bad assed little project. Ensuring the ECU is working is job 1. I take it there are no modifications yet to the engine or systems. That said, have you ensured that all of the original sensors are attached?
4000 then misfire could indicate a throttle position sensor error, a cam sensor error, a substantial intake manifold leak or a map sensor problem (im not a 1j expert by any means, so I propose only the common things that would affect running on various engines...they may or may not apply to your setup). I don't think Toyota ever built an ecu that could over fuel too far based on O2 sensor, but you might check it if you're stumped.
If as you said it smells rich as heck from the get go, it might think there is substanitally more air than there actually is going in, and may think you hit the rev limit at 4k...
Old 07-23-2008, 09:29 PM   #4 (permalink)
Thanks Bgrieger. I'll look more tomorrow. I'll do a boost leak test on the intercooler system. The ECU is actually modified but I suspect that it's not the modification that's causing the problem. It has a rare Buddy club, Black box which is piggybacked via ribbon wire to the ECU.
Old 07-23-2008, 11:04 PM   #5 (permalink)
View Fubar231's Photo Gallery
Man i dont know whats wrong with your car but that is tight! I wanna so a 1jz in a old school toyota truck and slam it. But, supra first, then, then who knows what. More pictures PLEASE!! Whats under the tarp?
Fubar231 is offline   Reply With Quote
Old 07-24-2008, 02:33 AM   #6 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
thats sick dude!!! I would love to see that thing in person. Quite the sleeper! I also saw two WRX's and an MK3 Turbo out front in the video. Very nice
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 07-24-2008, 08:02 AM   #7 (permalink)
I swapped the caps on the ECU this morning. I'm not sure if the board is damaged from the capacitor leakage but the issue still prevails. I'll try to scan the codes. I have to locate the two connectors to do that.
Here are some more pics.
http://www.flickr.com/photos/grabau/...7605048136837/
The car under the cover is my race car. It's an Evo.
Old 07-24-2008, 06:22 PM   #8 (permalink)
We just followed the procedure but the light is on solid. Does anyone know where there's a good 1jz forum? I need some answers.
I suspect the ECU but I don't want to swap parts without warrant.
Old 07-24-2008, 08:18 PM   #9 (permalink)
bgrieger's Avatar
the best sites might be in australia. That said, more locally there is supramania.com that has a small, but devoted 1j scene.
