Minor Update on my Car - Few new Toys... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2008, 04:32 PM   #1 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Just because the old thread was just that, Old.
First:
I got bored, and felt like making the Odometer match the engine:
[img]http://**********s.com/supra/images/qdig-files/converted-images/med_mileage.JPG[/img]
Yay for Low Mileage Mk3's!
Second:
Before/
[img]http://**********s.com/supra/images/qdig-files/converted-images/CoP%20Upgrade/med_COP-06.jpg[/img]
After/
[img]http://**********s.com/supra/images/qdig-files/converted-images/CoP%20Upgrade/med_COP-41.jpg[/img]
Three Cheers for no more coil packs!
Third
As of yet uninstalled [ ]
[img]http://**********s.com/supra/images/qdig-files/converted-images/CoP%20Upgrade/med_COP-02.jpg[/img]
ST Front sway bar, and Suprasport traction bars.
Fourth
B&M (Retail) Short Shifter:
[img]http://xd.**********s.com/uploads/7504ee29eb.jpg[/img]
Forgive the crap photo Better yet to come :-D I'm still re-learning to drive.
Old 07-28-2008, 04:44 PM   #2 (permalink)
View Fubar231's Photo Gallery
Very nice. Got a question about a few things, where did you get your front sway bar? My rear is rusting out and i need to get a new one, whatd it cost? Also same with the traction bars.
Fubar231 is offline   Reply With Quote
Old 07-28-2008, 04:51 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
All got 'em from friends local, but they can be purchased I believe from those vendors. ST and SupraSport.
Old 07-28-2008, 05:37 PM   #4 (permalink)
View SupraTuned's Photo Gallery
Nice
Nice Jeeves. Wish mine was together. I ended up having to deck the block, so she is in complete pieces. I like your equipment, I can't seem to remember where you said you got most of your parts from though. I have ordered a few things from jsc speed,but I have heard people have had problems with them. Let me know what you think...?
SupraTuned is offline   Reply With Quote
Old 07-29-2008, 02:39 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
My parts are from all over. There's so much custom work in this car that to say any of it came from any one major source is about as accurate as to say that the United States came from the South Pole. I mean, let's see:
- Custom Parts -
Turn Signals,
Intercooler
Pipes
BOV
Radiator
Electric Fans / Relays / Fuses / Thermostats
Oil Cooler
Intake
Intake plenum
PCV
Catch Can
Strut Tower Bar
HKS Long Runner Manifold
HKS External Wastegate
HKS Mystery Turbo
ARP Head Studs
ARP Rod Bolts
JE 0.020" Over Pistons + Rings
HKS MHG
Maft Pro + Speed Density Kit
Maft Pro Boost Controller
Coil On Plug Conversion
550cc RC Injectors
Aeromotive RR FPR
Charcoal canister Delete
A/C Delete
EGR Delete
Cold Start Injector Deleted
J-Tube Bypass
HKS Boost Gauge
Oil Pressure Gauge
HKS Turbo Timer
Zeitronix Wideband
1991 Non-Airbag Steering Wheel
1991 Climate Control
B&M Shifter (Rare)
B&M Custom spacer
Redline Fluid
Greddy SP Exhaust + Resonator
Walbro 255LRP Fuel Pump
etc.
etc.
anywho..
Old 07-29-2008, 03:03 PM   #6 (permalink)
How did you take our your CSI?
Old 07-29-2008, 03:30 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
I unbolted it. and bolted in a blockoff plate?
Old 07-29-2008, 03:33 PM   #8 (permalink)
It doesn't make your car startup weird or anything? Does the ECU still think its there or what? Taking out an injector just sounds like a iffy idea lol.
Does the stock fuel rail do fine with the 550 injectors?
Old 07-29-2008, 03:53 PM   #9 (permalink)
Got Hardass?
Jeeves's Avatar
That fuel rail would be fine with like, 1300CC injectors, it's huge in comparison to many many fuel rails. The ECU thinks it's there. I also removed the temp swich for it too though, so technically, it might try to run it Car runs great Not an issue at all for me. Car starts, goes to 1200rpm for about 40 seconds, then down to 1000rpm. Then once it gets up to about 1/3 on the temp gauge normal idle will kick down to 1/3 700-800rpm or so. When the elec fans kick on their load on the alternator will bring that down to 6-700.
Old 07-29-2008, 05:54 PM   #10 (permalink)
Lol well that works for you jeeves. Im assuming with the temp sensor out it probably just completely cuts the CSI out. Stops sending fuel and everything is my guess. Good to know our fuel rail is massive =] Ive been talking to some people who have mk3's around my area and a few of them run 14lbs of boost without hitting fuel cut. No afm / 550 injectors. One guy even runs 14.7 exact on a EBC and never hits fuel cut. Makes me think i might run 13-14 after i get my car back.
Old 07-30-2008, 10:53 AM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
If you think that matters on your car, you're foolish.
Just because one guy can do it, means nothing to your car, or my car, or anyone's car. If you don't want to listen to years of advice from hundreds of more informed individuals telling you the fuel system wasn't designed to sustain more than 12psi, and that the turbo is out of efficency beyond that. Then don't, fine. It's your car, your money, your parts, and your labor. But don't say you weren't warned.
Old 07-30-2008, 04:44 PM   #12 (permalink)
lol alright. so after putting new injectors in the car should i upgrade fuel rails/pumps anything like that? I figured at least a walboro pump or something.
Old 07-31-2008, 03:46 PM   #13 (permalink)
Got Hardass?
Jeeves's Avatar
So, there's a new thread with your name on it. It's stickied. Just in case you missed it.
Old 07-31-2008, 10:17 PM   #14 (permalink)
Wow i didn't even know you were running a MAF. What do you have to do to make the car work with a MAF? I don't plan on doing it, im just fine with the lxus-550 thing, im just curious. MAF's are usually for cars exceeding the limits of AFM's right?
Old 08-05-2008, 06:03 PM   #15 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
Lookin good Jeeves! I went to my local j/y and found a newer style steering wheel too (the 88 wheel is butt ugly!) and the guy said he would only sell it as the entire steering column. Gay as hell. Next time I go in i'm gonna take it off and say it was like that LOL
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
