Fun Stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2008, 05:33 PM   #1 (permalink)
View Fubar231's Photo Gallery
Fun Stuff
Finally got my car back from the headgasket place, drove 500 miles after 3 heat treatments, then turned it up. boost is at 10.5 right now and im debating if i should put it to 13? I had it on 13 and it ran good, but i dont think it ould be that good to run it on 13 all the time. Whats your opionions
Fubar231 is offline   Reply With Quote
Old 09-09-2008, 06:05 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Mod list?
Old 09-09-2008, 10:45 PM   #3 (permalink)
MBC, Apexi Intake, Muffler, and i hollowed out my cat. Cometic MHG and ARP Bolts at 90lbs. Brian crower valvestems and valve stem springs etc. Thats about it for now. I got other mods but thats the only power related ones.
Old 09-10-2008, 03:21 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
You didn't list any important fuel mods. Injectors, fuel pump or any other supporting mods to go over 12psi. Nor do you have any way to tell if you're going lean.
So, with that said, Lean it out if you can aford to rebuild it. Otherwise stay below 12psi. Fuel Cut is just the maximum overhead safety switch. The stock O2 sensor has no way to tell if you're rich or lean at WOT (Wide Open Throttle).
Old 09-13-2008, 09:44 PM   #5 (permalink)
Alright, im just going to run 11.5 psi till i get a wideband and can measure afr. If im going past 12 psi (Injectors, AFM, Fuel Pump) would i need a SAFC to tune it right or will it recognize it well enough on its own? Of course then fine tuning always comes into play.
Old 09-14-2008, 09:29 AM   #6 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
The supra TCCS recognizes nothing. It expects certain parts to be present. If you swap them out, tuning becomes your issue, as the ecu will keep trying to do what it is supposed to do with the parts it expects are present.
Old 09-15-2008, 09:52 AM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
Once you exceed stock boost (~7psi) the TCCS has no fuel maps (so it uses it's stock open loop map which was meant for stock boost) and you're relying on good luck to save you really.
