yea that makes sense. Well i know there's play in between the pinion and ring gear, from a dead stop on a flat surface when i go to take off i can hear the pinion gear slap the ring gear. but i dont think thats the problem. And its not so much a noise as it is actual shaking. I guess it could be the drive shaft, it didnt come with any balancing weights on it.
It doesnt shake at high speed is the odd part at least not too bad, like i said its only during a light take off very slightly releasing the clutch and putting the engine to just over 1K rpm. if it engage the clutch quicker and put the engine to somewhere between 2.5 - 3k it wont do it...
So would that diff. that is stated to fit the JZA70 fit under my car? i mean the mount points look the same from the picture...
1997 Toyota Corolla DX (R.I.P.) - bolt on performance parts... ~200HP
1975 Datsun 280Z - in the process of reserection and a RB26DETT drop......
1987 Toyota Supra T - Bone stock ~310HP so far....
