Fuel Leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2008, 12:30 AM   #1 (permalink)
View swifty650's Photo Gallery
Fuel Leaking
Help leaking fuel under 91 supra next to left front tire any ideas ?>>> Auto ingnorant sry and thanx
swifty650 is offline   Reply With Quote
Old 09-28-2008, 12:56 AM   #2 (permalink)
just a nobody
I think the fuel line runs along the left side of the undercarriage and goes up to the engine around there too. You will basically have to take a close inspection, too many fuel related items there, it can be anything.
N.E.O.
Old 09-28-2008, 01:15 AM   #3 (permalink)
kk im gonna see but i was told by a friend that it was the fuel line... where it connects to the engine sounds right . gas just drips real close to left tire
Old 09-28-2008, 02:12 AM   #4 (permalink)
heres what im gonna do jack her up tighten fuel line connections thinking thats a good start
Old 09-28-2008, 09:04 AM   #5 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
There are a series of connections in that area. If it is a turbo, there is the fuel line coming from the tank that meets a flex line from it to the FPD on the fuel rail. The return line also has the flex line from the regulator to the J tube on the side of the block, then from the j-tube to the hard return line. I understand the non turbo is similar, but the only way to find out is to crawl under there and start looking.
Old 09-28-2008, 11:07 PM   #6 (permalink)
thanx man appreciate it trying to keep this bad boy running for another 100k miles
Old 09-29-2008, 01:19 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
If you've got a whole mess of long extensions you can put them end to end and tighten it connections from the engine bay I believe that's a 17mm or maybe a 19mm. Should be attached to the motor mount.
