87'-7mgte: 2 to 4 cranks to get it started - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2008, 09:09 AM   #1 (permalink)
View flipmode64's Photo Gallery
Canada 87'-7mgte: 2 to 4 cranks to get it started
Hey guys,
Having this problem for a while and seems to be getting a little worse but maybe it's just me. Everytime I start the car up after its been sitting for multiple hours it will take 2-4 cranks of the key to get it started. Once started it works and idles fine (700rpm-750rpm area when warmed up). If I drive it for a while and then shut it off, it will start back up fine on the first try with no problems. Like if I go into Walmart or somthing for 20-30 minutes. When I park it at night and start it in the morning it just takes forever for it to get going.
Wondering what things I could/should be checking for?
Thanks for the help.
flipmode64 is offline   Reply With Quote
Old 10-02-2008, 04:38 PM   #2 (permalink)
Cgarman's Avatar
View Cgarman's Photo Gallery
Check the fuel pump. That what was causing this exact same problem on the wife's Camry. I went through the whole fuel delivery system. I went so far as to get a new ECU. Nothing worked. Changed the fuel pump a couple of weeks ago and BAM!!! no problems what so ever.
Cgarman is offline   Reply With Quote
Old 08-15-2010, 09:34 PM   #3 (permalink)
I just changed the spark plugs and it seems to start up in two cranks consistently.
Never touched the fuel pump.
