I have the sky brackets, and they do well enough. I am not a fan of the drive line brake. It puts a lot of strain on the t-case output shaft, and it dramatically increases the rotational mass of the drive line. Just get a simple line lock for the brakes. It is simpler and cheaper. If you are worried about spongy brakes, you can always buy some adapter fittings and put a bigger GM/Ford/Chrysler master cyl on.
I like a straight 6, but I do not think a turbo motor is a good match for off road. Unless you are playing in the sand, you will never spool the turbo.
The truck is a 97 Tacoma V6 with a Waggy 44 up front.
Don't you SAS me boy.
Please wheel responsibly.
