89 MK3 Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2008, 07:33 PM   #1 (permalink)
Boost Addict
View pgiller's Photo Gallery
89 MK3 Problem
I recently purchased a 89 mk3. I put a aftermarket fmic and hardpipes on it. The problem is when i go to drive it, it builds boost at first then cuts out and spudders and black smoke comes out of the exaust. Could it be my plugs?
pgiller is offline   Reply With Quote
Old 10-22-2008, 08:44 PM   #2 (permalink)
CRE
View CRE's Photo Gallery
Go over all of the intake plumbing. It sounds like a boost leak to me. If the pipes have welded on beads make sure the coupler is sealed well and clamped down securely AFTER the bead. I've seen a few sets of aftermarket IC pipes where the welded on beads were only tacked on in a couple spots and the rest would leak like a sieve if the couplers weren't installed well.
Have you checked for error codes?
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
CRE is offline   Reply With Quote
Old 10-24-2008, 07:03 AM   #3 (permalink)
Boost Addict
How and where could i check for codes?
Old 10-24-2008, 08:42 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Read the insturctions CRE gave you and you will know all you need to.
Old 10-25-2008, 07:23 PM   #5 (permalink)
Boost Addict
HA HA HA HA I found the boost leak. Problem fixed.
Old 10-27-2008, 12:17 PM   #6 (permalink)
1st time supra owner
View 90supraturbo's Photo Gallery
Where did you find the boost leak?
90supraturbo is offline   Reply With Quote
Old 10-28-2008, 06:01 PM   #7 (permalink)
Boost Addict
The pipe closest to the turbo. I fixed it and it runs like a raped ape. ha ha ha. I already out run my first 5.0 stang.
Old 10-29-2008, 06:50 AM   #8 (permalink)
MY I/C pipe that loops from under the fender into the intercooler is dry rotted and i'm having the same problem as you did.Is it possible its leaking thru there?
Old 10-29-2008, 07:14 AM   #9 (permalink)
Boost Addict
Possibly, I would get a set of hardpipes. u probably find a set at www.supramania.com in the mk3 for sale section. Or if possible buy a set of diy kit off ebay and make you own custom pipes.
Old 10-29-2008, 12:50 PM   #10 (permalink)
bgrieger's Avatar
Why. If you're not increasing power, they don't need to be replaced with anything but good stock ones you can probably find near free from people that upgrade to hardpipes.
Bob
Old 10-30-2008, 07:15 AM   #11 (permalink)
Boost Addict
Well i have heard that the factory ic pipes are more prone to cracks and leaks. Plus chrome looks sexy under the hood. :-)
Old 10-30-2008, 09:30 AM   #12 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
They are more prone to it. But I know people making > 380hp still using 'em today.
Simply put, if they're bad or leaking replace them. If they're in fine condition, don't.
Old 10-30-2008, 02:24 PM   #13 (permalink)
Boost Addict
you are right but my car didnt have any when i bought it so i went ahead and upgraded^
Old 11-05-2008, 05:58 AM   #14 (permalink)
I finally found the leak at the same pipe that PGILLER did.It was cracked behind the hose facing the firewall so thats why i couldn't see it.It wasn't till i got pissed and took off all the piping off the car to replace them that i found the leak.Thanks for the info guys.
Old 11-05-2008, 07:13 AM   #15 (permalink)
Boost Addict
No prob. How does it run now?
