1988 7MGTE Supra runs very rich - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2008, 10:11 AM   #1 (permalink)
2010 Toyota Corolla S
PhillyKorean's Avatar
View PhillyKorean's Photo Gallery
http://philadelphia.craigslist.org/cto/891871001.html
Hey Guys I am thinking about getting this Supra but I wanted to know what could cause the car from running very rich.
how would you tune this car to it wouldn't run rich and more lean.
It would be my first project supra ever and as you know I am not too familiar with this engine.
--------------UPDATE---------------
it needs a tune,the fmic pipe needs to be hooked up, as well as a bov, the throttle cable sticks a little
how do you install all these?
this is the description in the ad:
88 toyota supra turbo 5 speed it has the 7mgte engine with alot of work done to it, block is shaved, it has a Front Facing Intake manifold,ct26 turbo, 350z Rims. FMIC, Q45 throttle body., 3.5"Apexi turbo back exhaust, boost controler.battery relocated to trunk, it needs a new batt also. the car Dyno'd a 285 to the wheels on a stock fuel system and no tuning. it needs some body work in the rear, it also needs some minor work i have other tail lights for it,i just put a new clutch master cyl on it,it could use a good bleeding, it runs but it runs very rich, and it needs a tune! have more pics,
MUst SELL !!! $1400 firm....may trade
PhillyKorean is offline   Reply With Quote
Old 10-25-2008, 11:24 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
It's a modified car, and without knowing all of the possibilities, it could be an intake leak through to needing adjustment to the base fuel pressure to something the owner has screwed up. This is why I don't purchase someone elses hacks/projects without knowing them inside and out.
Old 10-25-2008, 07:29 PM   #3 (permalink)
Boost Addict
View pgiller's Photo Gallery
O2 sensor bad?
pgiller is offline   Reply With Quote
