Originally Posted by supranites90
since i have TEMS, would i need to get new struts along with the new springs that are TEMS compatible? or can i just get new springs to lower it some?
1) Never use your old stock dampers with new springs. They'll blow out within a thousand miles or so. 2) Your best bet would be to ditch TEMS altogether, as it's very dated technology. I recommend going straight to coilovers. Check out TIP over on Supramania. The guy you want to talk to is Wiisass. He
really knows the MKIII suspension.
If you don't want to get coilovers, grab some good lowering springs of your choice and a good damper, such as Koni Yellows. Make sure you do lots of research on the springs, though, and pick what's suited best for your needs.
My heater core replacement writeup with pics:
http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
