Transmission Leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 01:34 PM   #1 (permalink)
View suprabran's Photo Gallery
My transmission is losing some gear oil. I usually park in the same place and don't see any oil stains from leaking on the pavement. Where could it be leaking? And how can I find it? I was going to go get some A/C system dye and put some in it and use a UV light would this work?
suprabran is offline   Reply With Quote
Old 01-04-2009, 11:14 PM   #2 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
Is it an auto or a manual?
Typically i've seen with manuals either the seal where the driveshaft and yoke are coming out, will go bad starting to leak (mine is too).
Automatics could be leaking from the hosing going from the trans to the radiator or the pan gasket. I am under cars everyday and this is what i'm noticing.
Check those spots and let us know
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 01-05-2009, 08:42 AM   #3 (permalink)
It is a manual. If it is leaking in the drive shaft area, will it leave spots when it sits, or does it mostly show it's leaks when its running? I am getting a clutch put in soon so what else should I go ahead and replace while the transmission is down?
