WHEN ENGINE IS WARMING UP OR AT OP TEMP, THERE IS A GURGLING SOUND UNDER THE DASH. I SUSPECT THERE IS AIR IN THE COOLING SYSTEM. IS THERE GOOD PROCEDURE TO BLEED THE AIR OUT OF THE COOLING SYS? ONLY 1 THREAD THAT TALKS ABOUT ELEVATING THE FRT END BUT NOTHING ELSE FOR DETAILS.
ALSO, AT COLD START UP, THE DASH TEMP GAUGE WARMS UP NICELY AND HEAT BLOWS OUT VENTS, BUT THE MECH TEMP GAUGE SITS ON THE BOTTOM 100 DEGREES FOR AT LEAST 10 MINUTES WHILE DRIVING. THEN THE DASH GAUGE STARTS TO CREEP UP TO ALMOST TO THE REDLINE THEN THE MECH GAUGE SHOOTS UP TO 200 WHILE THE DASH GAUGE SIMULTANEOUSLY DROPS THEN THEY BOTH LEVEL OUT AT 180 DEGREES. HERE IS A PICTURE OF THE THERMO AND CONNECTIONS:
AS YOU CAN SEE THE MECH GAUGE IS DOWNSTREAM OF THE TERMO AND DASH GAUGE IS UPSTREAM.
THANKS
