Idles Up and Down All Day - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2009, 10:44 AM   #1 (permalink)
View remeinc's Photo Gallery
Need some help guys, I have an 88 Supra 7MGE stick, It idles up and down... no leaks on any hoses, bought a new MAF and that's not it, bought a new TPS and that's not it... bird cage light is on "when cold" then goes away...
Gave me a code of 24, air intake temperature (inside the MAF).
What in the world....anyone have any ideas?
RUNS REAL STRONG, NO SMOKE, NO NOTHING....only idles up and down when stop....
remeinc is offline   Reply With Quote
Old 02-10-2009, 11:24 PM   #2 (permalink)
View Mr. Lahey's Photo Gallery
My supra did that for a while. People always thought I was trying to race them at the lights. It was awkward. I think it was a vacuum leak. Look for a vacuum leak.
Mr. Lahey is offline   Reply With Quote
Old 02-11-2009, 06:17 AM   #3 (permalink)
Idles up and down
Same here pleople look at me like I'm stupido or something....but I check for vacumm leaks (test) there are none to be found.
Old 02-11-2009, 08:22 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
If you have a new MAF and the air temp is showing, you may have bad wiring or a bad ecu. Erratic idle can also be caused by leaks in the intake after the AFM or a bad or sticking idle control valve.
Old 02-11-2009, 08:59 AM   #5 (permalink)
Idles up and down
Thank you I will look into it...will let you know.
Thanks Again...
Old 02-26-2009, 09:33 PM   #6 (permalink)
TN's Pilot in Command
Christian87N's Avatar
Gameroom cash: $112320
View Christian87N's Photo Gallery
i second the bad idle control valve. I had a GS-R that did the same thing and it was a faulty ICV.
Get on, Get in, Hold on, Shut up
-Diamond Twinstar DA42-L360
-Cessna Skyhawk 172R
-ACA Citabria Adventure
Christian87N is offline   Reply With Quote
Old 02-27-2009, 06:06 AM   #7 (permalink)
Old 02-27-2009, 06:07 AM   #8 (permalink)
thank you, very expensive part looking for a used one.....
Old 02-27-2009, 06:49 AM   #9 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
My supra did this and rather than the ISC being bad, several of the wires going to it had either been strained or just aged and had broken. Some wire and some soldering later and everything worked as it should. Since it's an elaborate stepper motor if it can't hit some of the "steps" it will jump from one extreme to the other making it idle up and down.
Old 02-27-2009, 08:12 AM   #10 (permalink)
bgrieger's Avatar
Did you find the air temp problem in your brand new MAF yet? If it is a wiring issue, you can throw parts at it all day long and not solve anything.
Old 03-06-2009, 02:11 AM   #11 (permalink)
did you find the problem? For the idle control valve, i'd say go to some junk yard that specializes in japanese cars. Does anyone know if a valve from a N/A engine will work with a turbo? Maybe you can leach one off a regular 2JZGE
Old 03-06-2009, 10:56 AM   #12 (permalink)
Got Hardass?
Jeeves's Avatar
The N/A and GTE's didn't change that component.
Old 03-07-2009, 12:35 AM   #13 (permalink)
nice. then it might be cheaper to get it from an N/A like IS300/GS300/SC300.
Old 03-09-2009, 09:27 AM   #14 (permalink)
Got Hardass?
Jeeves's Avatar
I was talking about the 7M like the original poster asked. I can't vouch for that on the 1JZ/2JZ line.
