1jzgte vvti swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2009, 06:44 AM   #1 (permalink)
View bsilvias13's Photo Gallery
1jzgte vvti swap
i have an 88 supra 7mgte(rear sump) 5speed r154. and i found a 1jzgte w/vvti (rear sump) 5speed r154. is this still gonna be diffucult in an 88 supra?
Both engines are 5 speeds with r154 trans and rear sump oil systems.
i'm just wondering if all the other posts about this are just not complete as the should be on specifics.
thanks
-ben-
bsilvias13 is offline   Reply With Quote
Old 03-10-2009, 08:13 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
The VVTI are a nightmare to tune as I understand, and everyone says to stay away from them, but to physically bolt it in is not all that difficult. You need the newer subframe or there is a guy on supramania that makes custom engine mounts to bolt the 1J into the older chassis. Wiring harness also needs to be extended, and you can spend the hours researching all the rest of what is required here, on supramania and around as there is just too much to retype for you.
Old 03-10-2009, 12:30 PM   #3 (permalink)
Azsupracentral.com
View Phoenyxinferno's Photo Gallery
its only difficult to tune a VVTI only if you plan on shooting for high horsepower, but if you want it for daily use and reliability then there should be no issue, and the swap is pretty basic, the same as doing a regular 1jz into a ma70 Ive also been told the harness is longer but I havent seen one in person yet.
As far as motor mounts there is a dude Named Randy who runs BICperformance in cananda and he makes drop in motor mounts for 1j/2jz applications.
As far as wiring it up it depends on how you want to go about it, you can cut a 2.5" hole on the drivers side firewall and run the harness to the glove box then swap over your body connectors or you could go threw the hassle of extending the harness yourself. Or you could send your 7m harness and 1jz harness to Phoenixtuning to extend the harness for you for a fair price of $600 US.
Hope on supramania and do some reasearch they have all your answers there or they should at least...
Phoenyxinferno is offline   Reply With Quote
Old 03-17-2009, 03:09 PM   #4 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
I've also heard and read that the VVT-i is a nightmare. No point in it. If you want a 1jzgte, find one that's non-VVT-i. Just my 2 cents.
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 03-17-2009, 06:29 PM   #5 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
you guys just don't understand VVTi..
Jose Valle (the guy that swapped my engine) has a VVTi 1J in his "soapra"..
http://www.socalsupras.com/phpBB/vie...668&highlight=
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 03-19-2009, 09:43 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Noone has said that swapping a VVTi was hard, or that understanding VVTi tech was tricky. Tuning them for high hp was. If you want a DD/a hair more power out of one, all the power to ya.
Looking at that thread he just has a swap and hasn't even upped the boost.
Old 11-03-2009, 08:42 PM   #7 (permalink)
View onejzgtepower's Photo Gallery
hey guy sorry to hijack i am new and i have been reading fourms and i know you guys can answer me.my question is
i have a 1989 supra and i checked that the motor mounts are round so i think its not pre 89
i dont wana buy the 1jzgte motor and auto trany untill i find out what all i have to do
the 1989 supra is 7mge auto so i wana do a auto to auto swap
since my 89 supra is non turbo and to swap 1jzgte auto do i have to put the drive shaft from a turbo auto 7mgte supra ?
the wiring i can deal with them i will just change the ecu from passanger to driver side.
onejzgtepower is offline   Reply With Quote
Old 01-09-2010, 01:45 AM   #8 (permalink)
Coupera
View Ryan_V's Photo Gallery
Watch out for smog..the JDMs have no EGR and will fail visual if they're good.
95' Supra
98' Rav4
08' Toyota Sienna- shortblock replaced at 80k for $50 under extended warranty--> http://www.youtube.com/watch?v=nGYlO_peq1Q
Ryan_V is offline   Reply With Quote
