7MGE rebuild questions
i picked up a 7mge that looks like it was ran while it lost oil pressure. has a worn crank, worn cams, all cylinders need to be bored, pistons are shot with scratches all over the skirts. it needs alot of work, so here goes.
do they make a cam bearing for the head?
how much oversized do the main and rod bearings come?
Im thinking buying even a used long block is my best bet. hone the cylinders and throw a gasket set, timing set, oil pump and rods/mains.
i have searched an the cheapest 7mge used JDM long block i can find is around $700 shipped. ebay has a rebuilt long block for $1450 shipped, any one use this guy?
