'88 MKIII Auto Trans won't shift out of first gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2009, 03:03 PM   #1 (permalink)
View bambudist's Photo Gallery
1988 MKIII, Targa Top, Automatic, 7MGE
One day the tranny is working fine, the next day it won't shift out of first. Is this a solenoid problem or....?
Shifts into Reverse fine and into First but won't up-shift normally.
Anyone have a magic bullet for me to solve this problem? This is coming at a very inconvenient time. (but isn't it always?)
Any help greatly appreciated...
bambudist is offline   Reply With Quote
Old 03-19-2009, 01:43 PM   #2 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
I'm no automatic trans specialist but maybe you need a trans flush? I've seen cars and driven cars that their trans do the same thing. Total PITA's. After giving them a transmission service they shifted smoother. Not saying that the trans service is a cure-all, but it may help you.
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 03-20-2009, 08:53 PM   #3 (permalink)
Thanks, I did that and checking around, I believe it is a broken speedo cable connection. After find this out and looking for a cable, I found this.
http://tinyurl.com/dxqbyj
I will let you know if this fixes it.
Old 03-20-2009, 11:59 PM   #4 (permalink)
I Bleed TRD
Hopefully that's your answer. I'll be waiting to hear the answer
Old 03-21-2009, 05:26 PM   #5 (permalink)
After many telling me it was this and that in the Tranny, I found out that the coupling from the speedo cable to the Auto trans was broken. This is at the rear right side where the cable enters the housing. Without it working properly, the car will not shift out of 1st. I think is a pretty key piece of information for anyone who owns this car. Maybe others know this but I was unable to find that info here.
Anyway, I hope this helps anyone else. The part, small as it was, just brass fitting with a piece of cable, was $120. When I found that out, I knew this had to be a key piece because of how they priced it at the dealer.
Another fun and in this case happy Supra adventure!
Thanks!
