87 supra power problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2009, 06:57 PM   #1 (permalink)
View Heavy_D's Photo Gallery
hey guys i just picked up a 1987 supra, and for some reason, im getting no power at all now, it was running fine yesterday, seemed like if the motor was seized and made a couple clicks and every thing just shut off, like no power at all, not even the horn lights nothing, this is just a normal 7mge with a 5spd any ideas on what you guys think? i checked for fuses, they looked fine for me, one looks funny but idk
Heavy_D is offline   Reply With Quote
Old 05-19-2009, 08:40 PM   #2 (permalink)
bump, any one knows anything? just charged the battery, checked my fuses again, any one knows if there circuit breakers for a 87 sup?
Old 05-20-2009, 11:21 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Well, are you getting no power at all as in "No dome lights, no dash lights, no beeps, no horn, no nothing." as well as no crank? There's nothing on the +12V side, but you may want to check your grounds. Try pulling the main ground and following it, make sure nothing got chewed up. Also make sure it's getting a good connection at the battery. I've seen slightly loose connections/corrosion do some funny things.
Old 05-29-2009, 12:04 PM   #4 (permalink)
View Menace_121's Photo Gallery
what do you mean the fuse looks funny? also be sure theres no corrosion on the battery terminal also, that would caus a bad connection as well as the loose grounds, but if the battey is fine and fuses are fine then you have a bad ground or a bad positive wire
Menace_121 is offline   Reply With Quote
Old 06-16-2009, 08:53 AM   #5 (permalink)
View turbo4toy's Photo Gallery
I would check the Alt Fuse as well easy to skip over and sometimes they burn out where you can't see it. It is one of the big fusable links that is 80A or 100A something.
turbo4toy is offline   Reply With Quote
