need help oil main - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2009, 12:44 AM   #1 (permalink)
2jz king's Avatar
View 2jz king's Photo Gallery
need help oil main
well as you all kno i am new to the site my name is junnior
i own a 83 toyota corolla witch i will post pics of lator with a jdm 2jz motor
well this is my problem i am having. i keep blowing oil front main seals and cant find out what is the cause of this. if you all kno what can be the cause of this and can help me out it will make my life better this car is got me to the edge all ready lol.
2jz king is offline   Reply With Quote
Old 06-19-2009, 07:37 PM   #2 (permalink)
What is he doing?
View funky_monkey58's Photo Gallery
Next time you replace it use some silver silicone on the outer edge and cut half in inch off of the spring inside the seal.
funky_monkey58 is offline   Reply With Quote
Old 06-19-2009, 09:30 PM   #3 (permalink)
2jz king's Avatar
some ppl told me to doble it what do you think of that ?
Old 06-21-2009, 08:22 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
blown seals are usually blow-by related. Double the seal is an old trick that rarely works. Does the PCV system work? if you have it to atmosphere I'd do it the way the factory intended. If that is fine, then you may have much more significant issues like the rings being shot (though you should see smoke), or you may have crank walk (just a guess here that movement may be wearing the seal prematurely). Have a friend step on and off the clutch and see if the pulley moves...
bgrieger is online now   Reply With Quote
