Afr - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2009, 01:49 AM   #1 (permalink)
View SupraTuned's Photo Gallery
Afr
I apologize for starting a new thread, I probably could use the maft one but I didn't want to derail that topic. I have searched the web on A/Fr and can't really find any definitive info on it. I am completely new to the tuning scene, and I guess I need a crash course in air and fuel tuning. What is the prime ratio to be at throughout the entire rpm range? Which way is lean on the scale and which is rich? Meaning, is a rating of 10 richer or leaner? I would like to run just on the cusp of being just rich enough, I guess I would just like to know a safe number to run at so I don't fry my engine while I get used to this system. Any input would be apprciated.
SupraTuned is offline   Reply With Quote
Old 06-24-2009, 11:35 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Always remember it's stating the ratio of Air to Fuel. Hence Air / Fuel Ratio = AFR.
So, at idle and while cruising down the road, your car will aim for (from the factory) about 14.7:1 AFR.
Since you're always talking about one part fuel, that means that you're getting 14.7 times more air than you are fuel.
This is all fine and well for cruising down the road but in boost, the car needs more fuel. Now, the moment it gets boost it doesn't instantly need more but it will need to ramp up to about 11.7:1 AFR. If you go back to what I was saying, that is much less air to fuel in the mix, making it it a much richer combustion.
Low 12s aren't bad in boost but >12.3 (IMO, Others will get out of the throttle sooner, faster) and you need to get out of the throttle and fix the tune. Tuning often isn't a one man operation.
Crusing and daily driving is a much more lax endeavor, AFR's bounce (Bounce meaning it'll go above 14.7, then below, then above maybe for a while then below for a while... largely variable, sometimes very very rhythmic) -a lot- and there is much less to do in the tuning aspect. Depending on how it's all setup there may not even be tuning to do.
Old 06-24-2009, 05:28 PM   #3 (permalink)
I appreciate the input. That helps a good deal. It gives me a good idea to follow for tuning. I know I will have to mess with it a bit, but at least this way I know what to be aiming for.
