c26 turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2009, 08:13 PM   #1 (permalink)
Faster then a honda!!!!!
View 85supra's Photo Gallery
c26 turbo
I have a 88 supra with the 7mget. I am currently puting a head gasket in with arp studs. before i get it all back together i want to know how to check my turbo to make sure tha it is still good. the car has 200,000 miles on it. any help is greatly appriciated.
85supra is offline   Reply With Quote
Old 06-29-2009, 10:35 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
Short of taking it somewhere, look at the impeller blades. If you see chips or damage, you may have a problem. Check the shaft play by wiggling it side to side (radial movement), then end to end (axial movement). A small amount of side to side is probably ok. End to end movement is not so good.
That said, if it spools up, and seems to be alright, I'd just put it back in and be done. If you are particularly anal about getting it all perfect, you may need to look to a rebuild, or an upgrade.
Bob
bgrieger is online now   Reply With Quote
Old 06-29-2009, 08:10 PM   #3 (permalink)
Thanks for the help. There are no chips in the fins and there is no axial movement. There is some side to side but not bad.
If i were to go with an upgrade what would the best?
thanks
Kyle
Old 06-30-2009, 09:43 AM   #4 (permalink)
bgrieger's Avatar
Its a toss up. I like the 54-57 trims myself, as they produce great power, have excellent response (stockish) and still flow far more than stock. They also don't appear to have much in the way of reliability issues. Many prefer the 60 trims for the added power potential, but find them not as long lived in use. Speculation is that the large heavy 60 trim wheel may be too much for the shaft. They also usually need a clip of the turbine to really make full power and still flow enough exhaust, but that only serves to slow the spool down even more.
