Once you step away from a car's originally intended engine, it basically becomes a gut and swap. Gut everything, and find a way to put the new stuff in, and then experiment with getting it all put together so it can run. A 1uz would need mounts, plumbing, fuel system, engine management (standalone EMS), rewiring the dash and instruments, tuning and anything else you could think of from cooling to air conditioning. The 1J/1.5j/2j are the straight forward - and I use this word relative to other engines - SIMPLE swaps, but only because so much research exists already to make it fairly straight forward as to what is needed, and many of the custom parts exist from enterprising people that decided to make harnesses, mounts and other swap parts for them commercially.
