They are unrelated to a point. A waterpump run without water will eat the seal and may leak/fail. The timing belt is flat wrong, but as they said, it is an unrelated need to replace.
Things like bearings, shims, gears and shafts are damaged by lack of oil. overheating has it's own set of problems. Get your friend to get a second opinion on what is needed and why. Once they determine the cause, if required your friend can take the findings back to jiffy lube and see what they will do to rectify what oil and heat related problems are written up. If they refuse to help at that point, it is up to him, but I would ask if they stock lubricants like KY 'cause my lawyer/a small claims summons may be visiting.
