I've also found that bulldozering the vehicle until the power source becomes disconnected is also a method of disarming.
It's going. Just got me a new toy
[img]http://xd.**********s.com/uploads/09972b8689.jpg[/img]
I use megalogviewer, lemme dig up the easy steps to clean a log for ya.
To export a TunerPro log to CSV format to use in MegaLogViewer:
1) While in TunerPro click "Tools", "ALDL/Data Logging" then "Setup..." (Hitting F4 should get you to the same screen)
2) Select which session you want to export from the adl file.
3) Click the "Export Selected Session to CSV" button then enter a name and select a place to save the file.
4) Open Notepad (In XP, Click Start -> Run, type: notepad then click ok) and open the file you just exported.
5) Delete the entire First and Third lines.
6) Before the comma, add the word "Time". Your file should now look something like this (1 line of text, the rest all numbers(The exact words may be different)):
[IMG]http://xd.**********s.com/uploads/03345d661b.gif[/IMG]
7) Save the file and close notepad.
8) Start MLV and open the CSV file you just modified.
9) It'll bring up the "Please Register" window, but you can hit "Register Later."
10) If you did everything correctly, you should be able to click the boxes below the words "Graph 1", "Graph 2" and so on and choose what value you'd like to see graphed there.
MLV is
not designed to work with TunerPro or Supras, it just happens to be able to open CSV files after you modify them to its liking.
MLV can be found here:
http://www.ideasandsolutions.biz/msgraph/
