I have some ct26 upgrades available to the Garett T04E. I know a turbo specialist who has been rebuilding turbos for over 20 years, and and have access to an awesome ct26 upgrade. The stock exhaust housings are used, and everything else on the turbo is aftermarket, therefore being a "hrbrid" turbo. The turbo is a combination of T34 stage 3 exhaust combined with a 54mm high efficiency comp wheel (slightly larger than the standard T04E. It is built to match the crossflow (so intake and exhaust have similar flow characteristics). This turbo will have additional airflow, durability, faster spoolup and a considerate power gain. It is also very easy to install, as the original exhaust housings are used so it is a direct bolt on and requires very little modifications. It can handle up to 500 hp, and 25 psi. I installed this on my 91 celica alltrac and was extremely pleased on the difference this turbo made. There is no need on spending twice the amount on an aftermarket turbo for the same gain that you will get with this one. I would need the original ct26, and i can have it delivered with 2 weeks. Most places charge $1200-$1400 for this upgrade, but i can have it done for $850. Please email me at
dhruva_latorre@hotmail.com for pics or any questions. Thanks
Drew
919-302-7078
