Throttle Position Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2004, 01:48 PM   #1 (permalink)
View sxpear2's Photo Gallery
My 91 turbo wants to die when I quickly let off the throttle. It also has an intermitant miss. I've swapped the air fuel meter with a know good one and still have the problem.... Is this a symptom of a defective TPS? oh, yeah, I've replaced plugs and wires....
sxpear2 is offline   Reply With Quote
Old 03-08-2004, 09:58 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
Could be out of adjustment, or it is the dashpot under the linkage on the TB. Dashpots slow the final closing of the throttle plate, and help avoid starving the engine for air on quick throttle release. Basically gives the ISC time to compensate before finally closing.
As for the miss, plugs, wires, coils, ignitor, fuel injector, etc, etc. These are a bigger bitch to find.
bgrieger is online now   Reply With Quote
Old 03-09-2004, 06:31 PM   #3 (permalink)
View OneWingedAngel's Photo Gallery
You can test the TPS using the instructions found here:
http://www.cygnusx1.net/supra/librar...fi/FI_101.html
Also check for boost leaks. Are you still boosting your normal amount? You might also try cleaning the ISC.
OneWingedAngel is offline   Reply With Quote
Old 03-09-2004, 08:27 PM   #4 (permalink)
View cdnsupra's Photo Gallery
quickly dies when you let off? do you have a blow off valve venting to atmosphere?
you could also have an air leak in your piping system.
a worn spring on the tps can also cause weird idling problems.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
