1jz swap done but wont run - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2010, 03:40 PM   #1 (permalink)
View angel's1stsupra's Photo Gallery
Unhappy 1jz swap done but wont run
ok so im done with my swap only to find out the the car wont stay running, as i start it up is starts with a touch of the key but runs for a few seconds. try it again and it does the samething im thinking its a fuel problem anyone out there that can help me pls?
angel's1stsupra is offline   Reply With Quote
Old 01-08-2010, 07:11 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
You're probably on the wrong forum for this kind of information.
Old 01-08-2010, 09:40 PM   #3 (permalink)
What is he doing?
View funky_monkey58's Photo Gallery
What are you using for fuel pump control?
It could be priming with key on then shutting off.
I would try applying power to the pump with a constant source to see if that helps anything.
funky_monkey58 is offline   Reply With Quote
Old 01-09-2010, 01:24 AM   #4 (permalink)
Coupera
View Ryan_V's Photo Gallery
Yea, that sounds like the main fuel ecu relay is unplugged or not working at all. The ECU doesn't know to keep the car running. That or the pump isn't priming at all.
Common issue when doing the GTE swaps.
What car did you swap it into? Who did the wiring?
95' Supra
98' Rav4
08' Toyota Sienna- shortblock replaced at 80k for $50 under extended warranty--> http://www.youtube.com/watch?v=nGYlO_peq1Q
Ryan_V is offline   Reply With Quote
Old 01-09-2010, 01:25 AM   #5 (permalink)
Coupera
you could try supramania forums
95' Supra
98' Rav4
Old 01-09-2010, 06:57 PM   #6 (permalink)
thanks guys im going to check the relay first. its a 1jz swap into an 87 supra.
Old 01-09-2010, 07:04 PM   #7 (permalink)
i had my wiring done by Dr. tweek. were is the fuel relay located is it under the dash?
Old 01-09-2010, 07:59 PM   #8 (permalink)
Coupera
If he did the harness then call Tweak. He'll help you fix this for sure..he's a stand up dude.
I'd try searching supramania forums. They have a lot of good 1JZ specific info into MKiii chassis swaps.
95' Supra
98' Rav4
