Originally Posted by Camry_Man08
jeeves that is exactly what it looks like so it wouldn't be piston rings either? It also only overheats when i drive it and the coolant must be going somewhere but when my mechanic looked at it neither one of us saw coolant in the oil so what could be the overheating problem? By the way its a brand new radiator.
Because that's not where they are.
Loose piston rings will cause blow-by, excessive crank-case pressure and smoking. Not random oil up top. That extra pressure can cause excessive PCV venting, but that doesn't mean what you think it means.
So, let's quit using my mocked up diagram. While this isn't the 7M, it should give a far better feel, I've drawn in the metal cover sitting over the spark plug, the oil in the valve covers and the leaks.
Forgive the fact I saved it to a crappy format, but:
[img]http://xd.**********s.com/uploads/887d4daaf5.gif[/img]
That's close enough that it should make sense.
The combustion chamber isn't just filled with oil, carrying it up to the spark plugs.
As for overheating, I never once saw coolant in my oil when I've had BHG's. So, take that as you will. My coolant was leaking into the combustion chamber and being burned and I was pushing hot gasses back into the coolant passages.
Here's a cutaway side view of an engine (also not ours):
Can't see everything well, but this should look familiar:
[img]http://xd.**********s.com/uploads/58d091320b.jpg[/img]
So, neverminding ALL of this info. It's a WELL known issue.
