clutch stics to floor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2004, 08:31 PM   #1 (permalink)
View 87NASUPRA's Photo Gallery
hey guys first post here just bought an 87 supra non turbo and the clutch sticks to the floor but i can pop it back up with my toe i have heard a couple things so far like a clutch cylinder or a blown clutch. i just need some help on getting this sucker going thanks for your help.
87NASUPRA is offline   Reply With Quote
Old 03-17-2004, 07:10 PM   #2 (permalink)
View mymk3's Photo Gallery
clutch
Well, it is 100% either master cylinder or slave cylinder.
You can have them rebuilt at your local shop, or buy
brand new from toyota, but be prepaired to spend some
serious cash.
Cheers !
mymk3 is offline   Reply With Quote
Old 03-17-2004, 10:45 PM   #3 (permalink)
View Tosh's Photo Gallery
you ran out of clutch fluid meaning it's leaking somewhere.
fill it up, bleed it, check for leaks. (master and slave) the master is on the driver's side of the engine bay by the firewall and the slave is on the tranny.
the most common place you'll notice leakage is right by your feet above the clutch pedal.
clutch fluid is just plain old dot 3 brake fluid.
hth
boost is an addiction
Tosh is offline   Reply With Quote
Old 03-17-2004, 11:34 PM   #4 (permalink)
where would i refil it at ?
Old 03-18-2004, 01:52 AM   #5 (permalink)
take a look at the master, i'm sure you'll figure it out
Old 03-18-2004, 02:53 PM   #6 (permalink)
thanks alot for your time
Old 03-19-2004, 02:44 PM   #7 (permalink)
i checked the master cylinder and it was bone dry, so i filled it up bled it and then tried it again aand i got the same problems guess im replacing the master cyli next
Old 03-19-2004, 06:11 PM   #8 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
They are quite cheap from Toyota ($125 CDN last I did mine). Rebuilds were almost as expensive as a brand new one was. Made my choice easy.
Bob
bgrieger is online now   Reply With Quote
