ct26 rebuild - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2010, 11:28 AM   #1 (permalink)
Faster then a honda!!!!!
View 85supra's Photo Gallery
ct26 rebuild
Ok im rebuilding a ct26 turbo for my 88 supra but i cleaned the marks i made to line the wheels back up. Do i need to take it in and get it balanced as a unit or can i just put it back together? The wheels look like they were balanced seperately.
85supra is offline   Reply With Quote
Old 04-06-2010, 09:47 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
they are balanced as a rotating assembly when rebuilt, but might be seperately balanced at the factory...I wouldn't want to bet on it though given the downside!
bgrieger is online now   Reply With Quote
The Following User Says Thank You to bgrieger For This Useful Post:
85supra (04-11-2010)
Old 04-10-2010, 12:59 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
The shaft, compressor blade and nut need to be balanced. When reassembling, the nut will have to match a balance mark the shop will place on the compressor wheel.
The Jedi Speeder at CarDomain
The Following User Says Thank You to MR2Jedi For This Useful Post:
Old 04-11-2010, 07:38 PM   #4 (permalink)
I looked at my parts again and found marks from whom ever rebuilt the turbo before. i dot it together but it as .015 of an inch up and down movement is that to much or is it ok? it had .053 of an inch before i took it apart.
Old 04-11-2010, 08:04 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
What exactly have you done with this turbo? If you've taken it apart, everything on the small part of the shaft should be rebalanced. The compressor nut should not be reused, but replaced and balanced also.
Old 04-11-2010, 08:15 PM   #6 (permalink)
all i have done to the turbo is put a rebuild kit in it and i did replace the nut. i have not put the exhaust houseing back on it do i need to put it on or leave it off to get the turbo balanced?
Old 04-11-2010, 08:19 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
They only need the shaft and everything that goes on the small end to the compressor nut-including the nut.
Old 04-11-2010, 08:20 PM   #8 (permalink)
thanks now i just have to find a shop to balance my turbo.
Old 04-11-2010, 08:25 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Since you're in TX, contact ATS Racing and ask them who rebuilds their CT26's into CT27's.
They're in Denton.
www.atsracing.net
ph.....940-380-0719
