lights wont turn off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2010, 09:02 PM   #1 (permalink)
89supra884's Avatar
View 89supra884's Photo Gallery
well when i flip the head lights to the off position they just stay on, the blinkers dont work, and the tach does not work. are any of those 3 related.
thankyou
billy
89supra884 is offline   Reply With Quote
Old 04-17-2010, 08:10 AM   #2 (permalink)
89supra884's Avatar
no one else has had this problem, we can un plug the headlight solenoid, and you can hear it click and they shut off, but as soon as we put it back in the headlights just go back on the runners and dash lights will go off, just ot the head lights
Old 04-20-2010, 05:48 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
If you can get your hands on the Toyota Electronic Wiring Diagrams (TEWD) that diagram is Flyout Page #5.
The tach is it's own issue, can't really tell you what it could be with just "not working"
Headlights are are either the integration or headlight relay or maybe the multi-switch on the column.
Blinkers also run through the flasher circuit. Make sure you have the flasher button installed/plugged in. If it's not the flashers won't work.
Old 04-25-2010, 10:17 PM   #4 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
is your car a swapped NA?
usually using 89+ harnesses on pre 89 cars results in this..
NA and Turbo Tachometers are different, which is why yours doesn't work, and make sure your hazard switch is plugged in, chances are it's not..
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
