Originally Posted by professorbob
Thank for the suggestions. I have removed the crank pulley. Almost able to pull it by hand. Just purchased two two bolts to install a pulley remover only needed to turn the center bolt by hand and the pulley slid right off. The lower belt cover cam off and there was just a little belt residue. The belt looked exceptionally good with not cracks or ware noted.
The oil pump seal is damp and I would like to install a new seal. Anything I need to be aware of in removing the sprocket and the seal. What is the best way to reinstall the seal without damage.
Best tool for holding the sprocket for removing the center shaft nut. Also is there a way to check the pump condition. MM measurements etc?
I hate to admit, but I've never replaced one myself. The pulleys I find are easily removed with a strap wrench around the pulley, and an impact on the nut/bolt. Quick and simple.
For the oil pump, it can only be inspected off the car. You would have to pull the pan, remove the pump assembly and check it with feelers. Body clearance to gears is a max .2mm, gear backlash is .9mm, and side clearance (the gear ends to a flat bar laid across the pump opening) of .15mm. The relief valve should also be able to slide under it's own weight.
I've sent you a pm regarding the rest of it with detailed instructions.
Hoses. There are several 5 inch 90 degree water hoses. Were these pre-formed or just strait hose that was cut to fit and installed. I know there are several form fit hoses and with the exception of the accordion intake hose and a couple in high heat location are in really good shape. I really think they will go back with no problems. Really could use that OEM parts money to purchase other parts.
All are pre formed at their angles. Not all are actually 90 degrees, some are as much as 110 (didn't measure myself, but read something the other day on it.) If you'rez good with your parts guy at napa or others, you might just be able to find cheaper alternatives or similar hoses from other cars. No guarantee though.
I have seen several complete gasket kits on Ebay. Any thoughts about which brand may be better. I have basically stripped the exhaust side of the engine and plan on replacing all the gaskets.
Toyota has a full engine gasket set. You'll have kittens when you hear the price, but I haven't heard anyone that had good to say about the ebay kits. The Toyota kit is very specific on what it contains. The gaskets from turbo to elbow is not included, nor is the throttlebody and idle speed controller...so I found out the other day...If you are only tearing some of the parts down, you might be cheaper ordering the gaskets a la carte.
Turbo. The blower turbine has a bent leading edge blade. Have no clue how it got that way as this is the first time it has been apart to my knowledge.
Will this cause a failure of the turbine? I saw on on ebay for about 20 dollars, but there again do not know where I could get the thing rebalanced.
There is just a slight side to side end plan in the blower shaft and no back and forth play that I can tell.
I expect that I will need to install a seal kit and that may be quite a challenge.
Many suck little pieces of sand, dust, rubber or other over time and the fins get damaged. I would just keep running it if you didn't notice any problems. If you need to replace it down the road, you could get a used one cheap enough, or send it out for rebuild then. rebuild requires rebalancing as well, and you are likely just as cheap to get it all done at a shop as you are to peice things together at the end of the day, and you have something of a warranty in most cases.
I will be posting photos soon as I have some in progress shots of the internals around the cam shafts. Very clean.
Cam shaft. What is the best way to determine if the cams need shims.
The car was very quiet when it last ran. Is there a cold dry feeler gauge gap that I can check?
If you are in this far, will you be removing the head? If so, you should be sending this engine out to prepare for a metal head gasket. Even if you don't want to upgrade on power, the metal gasket properly done is a virtual guarantee that it will keep humming as long as you want it too!
