Take a look at
Rabid Chimp. They have a turbo kit for the MKII.
One rebuilt, factory spec CT26 Toyota turbo
OEM, ceramic coated, Toyota CT26 turbo elbow (02 sensor housing)
One turbo to manifold gasket
One high-heat (2000 degrees F) ceramic coated cast iron turbo manifold with 17mm manifold bolts
One exhaust manifold gasket
One Rabid Chimp turbo oil line kit with aluminum flanges, brass fittings, and stainless steel braided (teflon inner) lines
One set of turbo coolant lines, with necessary clamps, plastic Ts and brass hose barbs
One Rabid Chimp 3” mandrel bent, aluminized turbo downpipe, with copper gasket, and 3/8" thick flange
One re-usable open element air filter, with stainless steel clamp
One turbo inlet hose (mates turbo to air flow meter), complete with blow off valve recirculation and air valve ports, and stainless steel clamps (bottom of inlet hose has a fitting for power steering vacuum line relocation
One Cartech rising rate fuel pressure regulator, with high pressure fuel injection lines, vacuum lines, and hose clamps
One Rabid Chimp 24”x12”x3” intercooler (bar and plate design, Garrett core)
One set of Rabid Chimp 2.5” mandrel bent, powder coated intercooler pipes, with silicone hose couplings, and stainless steel hose clamps. Piping has a Greddy blow off valve flange, and goes all the way to the throttle body
One Greddy Type S blow off valve
One Split Second air/fuel mixture gauge
One Autometer Phantom vacuum/boost gauge (30psi)
One Walbro 255lph high volume fuel pump
One universal heated 02 sensor, with flange
Here is the
DIRECT LINK. Have fun. I was debating doing that myself... 65000 miles just seems too low to screw with the engine.
