My project 1989 supra turbo with targa top - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2010, 06:47 PM   #1 (permalink)
View Monkey123's Photo Gallery
First of all I like to thanks all the people for all of the advices and useful tips.
My Supra is an 1989 white turbo with targa top. I will changed exhaust manifod (leak), intake manifold (oil build up around gasket), water pump (leak, cooling drops at bottom hole), and oil leak. About the oil leak, I ran the engine in idle for 30 min. or more and see a few oil drops at the timing cover. I ordered crankshaft seal, 2 camshaft seals. I tried to order the oil pump seal at Autozone, Advance Auto Parts, Lee Auto parts, and Toyota dealers and none of the store carry it. Some store will sell oil pump assembly and it is a special order. I want to be ahead of the game and order it and replace it if the seal is bad. Does any one know where I can order the oil pump seal? If not, is there any alternative such as cooling hose? If cooling hose is used, what good it is? I was thinking about the Cresida since the engine is the same for the non turbo. I might get away by using the Cresida engine specs. After all the works are done, the body is next. After the body, I will send it out for painting at Maaco. They charged me around $500 stripping and painting the whole car for my Corolla. That's is all I can afford. Thanks for everything.
Monkies123
Monkey123 is offline   Reply With Quote
Old 07-07-2010, 08:38 PM   #2 (permalink)
View 1radtoy's Photo Gallery
the dealer is the safest place to buy the right seals. I also replaced both gaskets for the timing cover
better safe than sorry
1radtoy is offline   Reply With Quote
