2jzgte run on 7mge ecu? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2010, 09:00 PM   #1 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
simple as that....would a 2jzgte run on a 7mge ecu (auto ecu with 5 speed manual transmission)?
plyr503 is offline   Reply With Quote
Old 10-17-2010, 10:34 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
nope...unless you swap all the connectors and much of the harness there is no way. Even then, the ECU wasn't tuned for that particular 3L engine.
bgrieger is online now   Reply With Quote
Old 10-18-2010, 11:02 AM   #3 (permalink)
Cressida nut
Gameroom cash: $251045
View kamesama980's Photo Gallery
you might get it started and idling. you'd have to rig up some sort of a crank/cam position sensor to tell the ECU where the engine is (using a 2j or 7m distributor pickup) and use the distributor to direct spark (no COP or coilpacks for NA ECU) then deal with the 7mge AFM not being able to read 1/3 of the airflow the 2jzgte can draw so you'd have to do all sorts of crazyness there.....
short answer: Yes but you'd end up with less power than the stock 7mge engine. For the time and effort to get it to not stall or explode in boost or over 20% throttle or 2k rpm you might as well get a standalone.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 10-18-2010, 06:31 PM   #4 (permalink)
plyr503's Avatar
good to know....found a 2jz gte sitting somewhere it shouldnt be hooked up to a 7mge ecu I'm thinking thats why its there....couldnt get it running so they sent it to a scrap yard.....just missing the turbo!
