1JZ vs 7M Clutch Disc Diameter ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2010, 07:47 PM   #1 (permalink)
View 3SGTS's Photo Gallery
Hi i'm building a 91 Turbo MK3 with an R154 transmission and 2JZ-GE engine.
I' am going to use a 1JZGTE flywheel and bellhousing.
***My question is the following: Is the 1jz flywheel friction area greater than the 7mgte FW and therefore does a slightly larger clutch disk exist for the 1jz?
Yes I KNOW that the two clutches are interchangeable because they both use the R154 transmission spline but is the 1jz clutch grip area wider than the 7m is what i haven't gotten a clear answer for.
Thanks in advance for your input
3SGTS is offline   Reply With Quote
Old 10-22-2010, 09:18 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
My understanding is the disks are the same, but I'll look into it over the weekend.
Thanks,
Bob
bgrieger is online now   Reply With Quote
Old 10-23-2010, 10:30 AM   #3 (permalink)
bgrieger's Avatar
best info I can find says they are the same size, and that everything but the flywheel are interchangeable when using an R154. I'm getting that second hand though, so if there is another source that can confirm it you might want a quick check. Shops like driftmotion would be able to help you here.
The Following User Says Thank You to bgrieger For This Useful Post:
3SGTS (10-26-2010)
Old 10-24-2010, 05:42 AM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The 7M and 1JZ clutches are identical from the factory. Confirmed this.
All that is different is the flywheel and flywheel bolts, everything from there back is the same on the 7M and 1JZ.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff Lange For This Useful Post:
3SGTS (10-26-2010), bgrieger (10-24-2010)
Old 10-24-2010, 11:11 AM   #5 (permalink)
bgrieger's Avatar
And there we have it. Thanks Jeff!
Old 10-26-2010, 10:40 PM   #6 (permalink)
Thanks guys I was looking everywhere but that seems to be the case, Now to shop for a clutch that's drivable because it is going to be a daily driver but a badass one at that! , so its gotta be able to grip and handle some occasional launching
I've been suggested sprung hub for smoother shifting, girl will be sitting in the passenger seat at times
if anyone has a suggestion for a good yet somewhat affordable clutch disc, feel free to reply (puck, material, brands)
93 Celica GTS 3SGTE
91 Supra Turbo 2JZGE-T
Old 10-27-2010, 09:50 PM   #7 (permalink)
bgrieger's Avatar
Feramic based clutches are well regarded, and after driving a few I agree. They are a little grabbier than stock, but the material is just spectacular with low pressure plate weights and holds a lot more than the full ceramic and sintered metal disks and puck types. Mine is a full face south bend feramic that I got a chance to drive on another car a couple of years back (mine is still off the road...I might get one drive before the snow flies if things get less crazy at work, otherwise it waits till spring).
Engagement is very stock like. If you need more grab than that, multi disk clutches are great, but come at a very high price premium.
