2JZGE into MK3 ; any recommended Turbo Manifolds ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2010, 12:01 AM   #1 (permalink)
View 3SGTS's Photo Gallery
3rd Generation 2JZGE into MK3 ; any recommended Turbo Manifolds ??
Hello Supras,
So now I'm looking for a turbo manifold, I know so far it has to be specifically for a GE and not a GTE.
has anyone had any clearance issues with the manifolds when installed in the MA70 engine bay? any quality complaints??
there are ebay manifolds ~$130 , cxracing $170 , fab-worx $170 ,
max-redline $156 and some others
Thanks for the input
93 Celica GTS 3SGTE
91 Supra Turbo 2JZGE-T
3SGTS is offline   Reply With Quote
Old 12-23-2010, 10:25 AM   #2 (permalink)
View Camry_Man08's Photo Gallery
so correct me if i'm wrong but your going to be putting a turbo or turbos on a N/A 2JZ-GE?
Camry_Man08 is offline   Reply With Quote
Old 12-23-2010, 07:14 PM   #3 (permalink)
Yes one single turbo on a 2JZGE running on a 7mgte ecu, harness, and 440cc injectors. This is actually a common setup at least here in South Florida.
Light boost not too extreme ~~17-19 lbs
93 Celica GTS 3SGTE
Old 12-24-2010, 02:02 AM   #4 (permalink)
well thats new to me never heard of someone or anyone running a 2jz-ge off of a 7mgte ecu i hope that works for you but if you want a single turbo manifold for your set up its going to be custom no matter what witch will cost a pretty penny but if i had your set up i myself would go with BIC Performace they have some really sick looking stuff for the swap they did from a 7mgte to a 1zjgte but you might be able to send them an email at info@bicperformance.com and just let them know what your looking for and they will help you get the most from your set up let me know what you find out good luck!!!
Old 12-24-2010, 08:37 AM   #5 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
The swap is "fairly" common (perhaps a half dozen times, and it is quite well documented). Nobody has ever said anything about the manifolds and if any don't work though, hence I hadn't jumped in yet. It seemed at supramania that they were using generic ebay manifolds given the prices they quoted.
bgrieger is online now   Reply With Quote
Old 12-28-2010, 10:30 AM   #6 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
my friend does swaps like this in SoCal..
I am personally going to go 2JZ-NA-T using 7MGTE electronics, including VVTi coils, so I can run GTE valve covers, and go with a FFIM..
of course this is a year or two away, but it can be done...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
