Signal Lights / Hazard Lights problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2004, 07:42 PM   #1 (permalink)
View Z0rn's Photo Gallery
Question Signal Lights / Hazard Lights problem...
The other day I was driving to work and noticed my signal lights stopped working, they only work periodically then without notice stop working again. I've changed all the fuses and even switched the signal relay from my old Supra... after checking the one that was originally in my car that works fine as well. The strange this is, that when my signal stop working so does my hazrads. Then when my signal lights work again so do my harzards. This goes back and forth and I cannot figure out what the problem is for the life of me. The hazards and signal lights are on two different fuses. Why do they work and not work in unison?
87 Supra Turbo (Targa)
Z0rn is offline   Reply With Quote
Old 05-02-2004, 04:03 PM   #2 (permalink)
Well, I fixed the problem, after taking out the flasher and cleaning up the connections I noticed when wiggling some wires coming out of a big connector the hazards would work and then not work depending on how I wiggled the wires. One of the big connectors had been pulled out and was basically hanging by a thread so that when I wiggled the wire it fell out. So I plugged it in all the way, there was a quite a difference in position from where it was sitting to where it was when I plugged it all the way. Problem fixed... Cheers.
