Water pump leaks on 1989 Supra turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2011, 05:47 PM   #1 (permalink)
View Monkey123's Photo Gallery
Thanks in advance for any advice. I have a 1989 Toyota Supra Turbo with Targa top. I changed timing belt timing belt tensioner, crankshaft seals, camshaft seals, and water pump of last year in June. I don't use the car much and it is kept in the garage. Now the car is leaking a small amount of cooling at the water pump. I forgot to pay attention when taken out the water pump. There are long and short bolts. Does anybody have a diagram or drawing of the bolt pattern. By the way, the water pump was brought at Autozone.
Monkey123 is offline   Reply With Quote
Old 02-26-2011, 07:20 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
If the bolts fit in, you didn't mix them up. The long ones will bottom out in a short hole long before you contact the surface of the pump.
Did you check to see where the leak is coming from. I take it from your question you suspect it is the gasket, but if might be the seal for the shaft as well. Most pumps have a "weep" hole where fluid that gets past the seal and bearing can escape.
