Cressida starting problems, same engine as Supra???
I have a 91 Cressida. Starts fine when engine is cold. Starts fine when engine is hot, but after it sits for 10 minutes or longer when hot, it offers problems. It will start, but dies, it pings and makes a racket, I rev it high rpms, seems to do better. It will have to be started several times, may take two + minutes to settle down. May not be as problematic with premium gas, but still has problems.
Local dealership checked the computer, did not find anything. Suggested possible leaking fuel injector. Leaking fuel injector would not be worth fixing, even if that is was the problem. I replaced the fuel pressure regulator, no help.
Any thoughts?
Thanks,
Greg
