1990 Supra Non-Turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2004, 05:25 AM   #1 (permalink)
View hawaiianeye's Photo Gallery
Identification of Oil Leak Part:
Help Wanted from Supra Owners -
Located next to the oil filter's right side is a round cup screwed into the block with a plastic cover connected by a thin wire.
This area has an oil leak, so I would like to find out the name of this part ( with gasket? ).
Thanks form Hawaii
hawaiianeye
hawaiianeye is offline   Reply With Quote
Old 08-23-2004, 12:41 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
This is the Oil Pressure sending unit. Typically it can leak if not properly tightened, but there is no gasket. The cam position sensor is higher up and further right, but often the rubber ring sealing it can leak and drip down to the Oil Pressure. Also, valve cover gaskets could cause a leak in the similiar area. I suggest you make sure that the sensor is properly tightened, then check the other two possibiliites.
Old 08-24-2004, 05:10 AM   #3 (permalink)
Mahalo (Thank-you) from Hawaii
Jeeves
hawaiianeye
hawaiianeye
