Originally posted by wonknown
the head gasket is a metal hks..the headgasket was replaced along with a rebuilt engine...so the head gasket is fine.....i will look into your advice along with my friends who know more about cars than i ever did....
Just because the HG is a Metal HKS HG doesn't mean much.
If it was installed with proper hardware (see ARP Head bolts or studs (Stock Bolts aren't great for MHG's) and on a motor that had the head
AND block resurfaced, you've got a much much better chance however.
Metal HG's are notorious for not sealing properly unless all surfaces are machined. If only the head was done, it can very easily be blown. Likewise if only the block was done. On top of that, stretched (reused) stock head bolts and improperly torqued bolts/studs can cause similiar failures.
