Car dies for no reason!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2004, 02:47 PM   #1 (permalink)
View gearhead789's Photo Gallery
Exclamation Car dies for no reason!!!!!!
I have a 1990 MKIII turbo 5-speed. I've replaced the fuel filter, pump, plugs, air filter. I've replaced the throttle position sensor, and cleaned the intake. I will be driving for 5 minutes to up to 1 hour and then for no apparent reason whatsoever the car dies. It will start to sputter, lose rpm's, then I start smelling un-burned fuel and as soon as I take my foot off of the clutch the thing dies completely and won't start back up until I let it sit for about 5 mins. This has done this about 5 times in the past week, I'm lost someone please give me some suggestions.
Thanks
gearhead789 is offline   Reply With Quote
Old 10-25-2004, 01:57 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Try jiggling the wires around the cam position sensor. It's a long shot and the symptoms don't match, but it's often a cause of sparatic dying.
Old 10-25-2004, 02:06 AM   #3 (permalink)
View 88SupraMKIII's Photo Gallery
I had a similar problem with my 88 N/A. It didn't do it as much as yours. Mine died twice on me, the first time it started back up but the second time it didn't. I thought the same thing that you did. Checked fuel pressure, checked spark, checked air....turns out it was as simple as the Rotor just got totally burned out. Don't know if it's the same as yours but it's a thought.
88SupraMKIII is offline   Reply With Quote
Old 10-25-2004, 02:10 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
The turbo models use a coil pack ignition system and not a distributor, so there's no rotor to burn up.
Old 10-25-2004, 02:14 AM   #5 (permalink)
ahhhh...gotcha. then totally forget what I just said.
Old 10-25-2004, 02:55 PM   #6 (permalink)
thanks for all the replies, i'm going to try ohming out my coil pack, I have another one also, I'll try that one too, I'm lost after that though.
Old 10-30-2004, 09:42 PM   #7 (permalink)
View Krypto's Photo Gallery
The wires going to your Cam Position Sensor have gotten either corrded or broken inside. This is a very common issue in the MKIII Turbo's. Double check all the connections...place some electrical grease within the connectors and make sure they're making proper connection.
Kruso
Krypto is offline   Reply With Quote
Old 10-30-2004, 10:07 PM   #8 (permalink)
View shockel's Photo Gallery
Don't these cars have a self diagonsis on the computer? If so try it.
shockel is offline   Reply With Quote
Old 10-31-2004, 12:39 PM   #9 (permalink)
Short out the E1 and the T1 pin under the diagnostics box and the code will give you a pretty good idea asto what it it is. But unfortunately in his case he'll be lucky to find any codes in the ECU. Its rare to find a code with this issue.
Kruso
Old 10-31-2004, 12:55 PM   #10 (permalink)
View mblnnash's Photo Gallery
Lightbulb Car dies for no reason!!!!!!
Greetings,
Your problem is a relay....
Check the codes that are generated, and then follow the step by step troubleshooting procedures. If it sets many sensor codes, I would suspect the ignition relay (Main EFI Relay).
You should probably clear all codes, then drive the car to failure; a fresh set of codes may prevent you from chasing unrelated issues.
Keep in mind, relays may seem to work while testing, but with eroded / worn contacts, can fail when you hit a bump, or at a certain temperature. Don't trust the fact that a relay tests good, since you can't mimic its operating conditions.
Good luck,
-MaTT-
mblnnash is offline   Reply With Quote
Old 11-01-2004, 01:34 PM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
Shockel,
These cars are OBDI, not OBDII. Jumping those pins does flash the codes at you, but they're almost worthless for issues like this.
Old 11-01-2004, 04:12 PM   #12 (permalink)
OBD1 codes are quite useful to someone who knows how to use them. Especially if it is all you have to work with. I have resolved a many issues with information supplied via ODB1 computers.
Cheer up,
-MaTT-
Old 11-02-2004, 03:48 PM   #13 (permalink)
Jeeves is correct in this matter. These codes will NOT register for your problem. MBLNNASH, I constantly use these codes to keep my manitaned and problem free. On these cars checking codes for that problem wont do him any good.
Kruso
Old 11-02-2004, 04:26 PM   #14 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
If the Supras are like the 89-92 Cressidas, they're not exactly even OBD1. Some OBD stuff, and some proprietary Toyota stuff.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 11-02-2004, 04:33 PM   #15 (permalink)
Kruso,
Perhaps Toyota put them there for no reason?
I don't remember any of the instructors mentioning "codes are of no help" in any of the Toyota certification classes I attended.
Perhaps you did...
-MaTT-
