Krypto's wrong. You almost never want to "top off" a radiator by adding coolant to the radiator (other than when installing a new radiator). You add it to the overflow reservoir. Most overflow reservoir's are white(ish) containers that have a smaller line running from the radiator to them. In the Mk3 Supra it is next to the drivers side headlight between the bumper and hood support bar.
You'll also note that there is a "fill" line on the overflow bottle to indicate where it should be. If you just topped off the radiator, you don't know if the heater core is open, or what, and you will be low on coolant.
