"but there is some play when moving the turbine side to side."
How much play? Some (see: enough to feel it) is common, but not bad at all.
Also just look at the condition of the blades on the impeller. I had a turbo whine since it was installed, turned out at some point something hit the blades and screwed the edges up nicely. This was causing my whine.
A whistling sounds more like an exhaust leak. Re-install the turbo, tighten all the bolts and go for a 5 min. drive. If it whistles, pull it and have a rebuild. Also look for for gaskets on the turbo -> elbow/downpipe area too.
