NA to TT Conversion problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2004, 12:22 PM   #1 (permalink)
View SlowNA's Photo Gallery
OK here is the situation,
I have a 1994 Nonturbo Supra
and I bought a TT engine fron a 1994 that was an automatic w/harness.
-I want to use my 5spd trans,flywheel,clutch,etc
-Will the Automatic harness work as long as I am using the TT 6-spd computer?
-Will my 5spd trans be ok as long as I keep the HP level down at a factory level?
thank you very much if you need any other information please ask I need to find out soon before my warentee runs out on the engine
Email SpoolinLS@yahoo.com
SlowNA is offline   Reply With Quote
Old 11-26-2004, 12:35 PM   #2 (permalink)
Gameroom cash: $147537
Isn't the auto capable for 1000HP?
Old 11-26-2004, 12:38 PM   #3 (permalink)
mkivsoopra's Avatar
View mkivsoopra's Photo Gallery
The harness will work. You WILL need a new clutch though. There's quite a selection here: http://www.horsepowerfreaks.com/Show...ategoryCd=CLUT
Be sure you get a clutch for the NA 5spd.
I'm going through the exact same process, except my engine came from a 6spd car. Cross your fingers and hope your tranny will last. They're sometimes known to blow at 300 ft-lb, but for some people they hold in excess of 500 ft-lb.
www.mkivsoopra.com/project
mkivsoopra is offline   Reply With Quote
Old 11-26-2004, 12:39 PM   #4 (permalink)
mkivsoopra's Avatar
No, the stock auto tranny is capable of holding nothing near 1000HP.
Old 11-26-2004, 04:23 PM   #5 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
So what's the NA 5-speed tranny in the MKIV? Not a W58 (or variant), is it?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 11-26-2004, 05:37 PM   #6 (permalink)
mkivsoopra's Avatar
yes, it is the infamous W58!! The shifter is different though.
http://www.mkiv.com/specifications/ncf/ncf93/ncf124.jpg
Old 12-13-2004, 12:20 AM   #7 (permalink)
View Rktboy3802's Photo Gallery
if you want to put a stick on an auto the biggest thing is that you need a new ecu that came from a stick version of your car
Rktboy3802 is offline   Reply With Quote
Old 12-13-2004, 12:37 AM   #8 (permalink)
mkivsoopra's Avatar
I wouldn't say it's the biggest thing, although it would be nice to have. The auto TT ecu will work just fine with a manual tranny sitting behind the engine. It will, however, pull timing between the shifts as if there was an auto.
